Jump to content
Shaihulud
Deep Sky Planetary Technique (by Shaihulud)
Recommended Posts
21231886_1399238176821412_3232074568487930048_n.jpg.7b734ddcb96740a1fdbd61020bda11e1.jpg
Hello hello
Voili voilou tous mes snipes CP pose courte ūüėÄ
depuis mon centre ville de Reims & depuis ma new lauch base
Mes animsssssss
http://www.astrosurf.com/topic/114374-shaihulud-airline-animationsssssssssss-88-gif/
My favorite shivers ūüėć
01 - http://www.aapodx2.com/2016/20160611.html
02 - http://www.aapodx2.com/2017/20170316.html
03 - http://www.aapodx2.com/2017/20170926.html
04 - https://www.facebook.com/photo.php?fbid=10213062993763257&set=gm.1728992230445447&type=3&fref=mentions
05 - https://www.facebook.com/photo.php?fbid=10212527527126760&set=gm.1671312276280300&type=3&fref=mentions
06 - https://www.facebook.com/asterastronomy/photos/a.1200634403351263.1073741828.1199207560160614/1609290422485657/?type=3&theater
07 - https://www.facebook.com/photo.php?fbid=10215702107766609&set=gm.1875780095766659&type=3&fref=mentions
08 - https://www.facebook.com/photo.php?fbid=10212999005033413&set=gm.1735302586547935&type=3&theater&ifg=1
09 - http://www.stelvision.com/galeries/image.php?id=1543
10 - https://www.facebook.com/groups/1009891179089083/permalink/1974003936011131/
11 - http://www.aapodx2.com/2018/20181226.html
12 - https://www.facebook.com/optiqueunterlinden/photos/a.197004731058517/394988184593503/?type=3&theater
13 - https://www.facebook.com/photo.php?fbid=2093936864018203&set=a.960221347389766&type=3&theater
14 - https://www.facebook.com/photo.php?fbid=10218831812927282&set=gm.2444401052237891&type=3&theater&ifg=1
15 - https://photographingspace.com/iotw-may-27-2019/?fbclid=IwAR2HN3RXT6QFdAYr_4qMF2h162urNYvXUcfAoOBjfs6sOC5Uj8muLc2aVeg
16 - https://www.facebook.com/photo.php?fbid=10217091778800365&set=gm.2481215665223096&type=3&theater
17 - https://www.stelvision.com/astro/photo/82/?fbclid=IwAR3lEmqTwJDb7VlDOZwMGSjoVJbo0QvzYG4xf4EJW4Iykcvm85OCDmMABQg
Approved sharing APOD (FB) ūüėć
01 - https://www.facebook.com/AstronomyPictureOfTheDay/posts/1869224273113025
02 - https://www.facebook.com/AstronomyPictureOfTheDay/posts/1869229426445843
03 - https://www.facebook.com/AstronomyPictureOfTheDay/posts/1870792762956176
04 - https://www.facebook.com/AstronomyPictureOfTheDay/posts/1872166406152145
05 - https://www.facebook.com/AstronomyPictureOfTheDay/posts/1890720204296765
06 - https://www.facebook.com/AstronomyPictureOfTheDay/posts/1890715160963936
07 - https://www.facebook.com/AstronomyPictureOfTheDay/posts/1970930302942421
08 - https://www.facebook.com/AstronomyPictureOfTheDay/posts/2043340025701448
http://www.astrobin.com/users/Shaihulud/
https://www.facebook.com/shai.hulud.13
https://www.facebook.com/groups/812970845492793/
https://www.youtube.com/user/shaihuludshaihulud
https://www.webastro.net/profile/123106-shaihulud/
David
„Éá„ā§„Éď„ÉÉ„ÉČ
Edit 20190410
Deep Sky Planetary Technique 4.0 FAPSC (by Shaihulud)
(F) Pour les acquisitions avec Firecapture :
- Je commence √† filmer quand le soleil passe -15¬į
et je stop quand il passe les -15¬į.
- cadrage de l'objet avec Stellarium.
- mise au point sur étoile lumineuse mini de magnitude 6 au bahtinov.
- collimation une fois la mise au point correcte pour le mode newton.
- re mise au point définitive sur l'étoile et direction vers l’objet.
- détection de point chaud avec le bouchon et avec les mêmes
réglages que les captures.
- ser de 3600s soit 3600x1s, 1800x2s......
- ser dark de 360s soit 360x1s, 180x2s.....
- re détection de point chaud avec le bouchon et avec les mêmes
réglages que les captures. Théoriquement, le nbre de point chaud
diminu par rapport à la session d'avant.
- re ser de 3600s
- re.....
(A) Pour le pré-traitement avec AutoStakker3 :
- ouverture du ser.
- fenêtre de visualisation : icone sav current all au format Tif.
- ouverture du ser dark.
- fenêtre de visualisation : sav current all au format Tif.
- visualisation des Tif avec visualisateur windows en mode rapide
et suppression des images satellites, avion, nuages, étoile filante......
(P) Pour pré-traitement avec Pipp :
- onglet images : chargement des Tif provenant d'AutoStakker3.
- onglet dark : chargement des Tif dark.
- onglet out : sélection fichier de sorti en ser.
- et clic start pour la création du nouveau ser.
(S) Pour l'alignement et l’empilement avec Siril d'une session :
- ouverture fichier ser provenant de Pipp.
- implantation d'une zone de détection, clic droit et sélection d'étoile dans la fenêtre visualisation.
je sélectionne une étoile qui éclaire pas fort sur l'image sinon, Siril est moins bon.
- onglet alignement : détection sur étoile, suivi déplacement et clic alignement.
- il faut que je n'ai pas d'image non détectée.
- onglet empilement. Somme. sélection par FWHM.
- clic empilement FWHM2,00. Puis clic FWHM2.25. Puis clic FWHM2.50.....
et fermeture de Siril.
- Idem pour la session de 3600s suivante.
Pour l'alignement et l’empilement avec Siril de plusieurs sessions :
- ouverture siril.
- icone + et sélection de tous les Fit genre de FWHM3.00
- conversion en Fit.
- onglet alignement. mode global et clic alignement.
- onglet empilement. somme, clic empilement et fermeture de Siril.
Pour le retrait de gradient :
- ouverture siril.
- ouverture Fit empilement final.
- fonction extraction de gradient. Ordre 1. implantation de 5
carré en colonne à gauche. Idem à droite. calculer appliquer.
- enregistrement sous Fitgrad non codé.
- et enregistrement sous Tifgrad.
(C) Pour traitement, j'utilise toujours CS2........
Voili voilou mon dernier process.
A+ pour peut-être une version 5.0
David
C'est mon snipe coup de coeur car je trouve le jet de matière de 5 000 al excellent :wub:
Si je peu, j'ai prévu de resniper la belle mais barlowté à x2.
Mon objectif était IC1296 :)
Cette beauté je la kif de chez kif
http://www.aapodx2.com/2017/20170926.html avec @Ryo  :wub:
Avec une ED80, c'est aussi excellent. :cheesy:
Edited by Shaihulud
Share this post
Link to post
Share on other sites
Whaou !!!! Quelle moisson David !!! Magnifiques tous ces shots !!! Nice nice nice job !!!!
:b::wub::vague::fete::bond::1e::leb::god::1010::cheer::banana::break:
Share this post
Link to post
Bravo ;)
Mais faut pas s'arrêter là ! La pose courte c'est l'avenir :D
Romain
Share this post
Link to post
Superbe série !
J'aime beaucoup M1, vraiment très détaillée.
Le truc vraiment intéressant, c'est l'étoile qui se déplace sur les deux photos de NGC2261.
Share this post
Link to post
Quelle année!! :)
mes préférées M1 et M64 avec en numbeur ouane cet Iris tout en retenue aussi beau qu'un dessin de Fred :wub::wub:
Share this post
Link to post
Impressionnant David
Se sont de sacré snipe
H√Ęte de voir eux que tu vas nous sortir sous un meilleur ciel
Et merci encore pour ton aide Olivier
Share this post
Link to post
J' aime bien ton sombre héros. Chapeau pour ton dada derrière les nuages.:)
Je vois aussi que tu as enfin retrouvé M13.:D
Bizz
JM
Share this post
Link to post
Une sacré collection, c'est un très beau travail car pas évident sous un ciel de ville.;)
Waouh, c'est magique:wub::wub::wub:
Félicitations pour tous ces snipes de folie.
A bient√īt David.
Share this post
Link to post
Hello hello ;)
Merki merki Ted, JP, Romain, JF, David, Gérard,
Julien, Bracouda, Franck, JM & Deep impact :)
@Romain & JF :
Don't inquiet you :p je vais pas m'arrêter là.
Le polemaster arrive et il va falloir que je test ma new cam : une 174MM :)
Si un jour on arrive à voir le sky :cry:
Le 254/1200 a encore de beau snipe devant lui le temps
que le 305/1200 passe les tests désaluminé pour le moment.
@Gérard & Franck:
Je suis dég pour M1. J'avais prévu de faire 4 big session de novembre
à février pour faire un gif de l'onde du pulsar :( et les
nuuuuuuuuuuuuaagggggees ne me l√Ęchent poooooo :mad:
@David:
C'est gr√Ęce √† ce shoot que j'ai d√©couvert les √©toiles vagabondes.
Je connaissais pooo avant.
J'en ai cherché une autre à shooter mais j'ai pas trouvé :(
Il y en aurait une dans M57 mais il faut un échantillonnage de dingue :cry:
@Julien:
Yes yes. The end pour les snipes terrasse :p
@JM:
Biz biz
Moi, je préfère le couvre mexicain derrière l'oculaire de ton 560 :wub:
J'ai encore dans mon cerveau cette beauté.
Vivement les NAT pour pouvoir la revoir en mode gogo. Hihihi
Edited by Shaihulud
Share this post
Link to post
La gravit√© √† l'air vachement forte dans ce coin, les b√Ętiments sont quelque peu √©cras√©s ! :D
  • Haha 1
Share this post
Link to post
Waaaah! J'adore le traitement de tes galaxies, elles ont un relief saisissant !
Tu as je trouve un "style" dans le rendu de tes images.
Magnifique , merci!
Share this post
Link to post
Superbe série David :wub: je te souhaite de bonnes sessions pour 2018 dans ta nouvelle base :)
Share this post
Link to post
Très bon :D:D
Share this post
Link to post
Franchement, tes résultats sont incroyables, il y a de vraies pépites dans tes images. De plus tu as obtenu de très belles images en très peu de temps, cela mérite bien un :1010:
Share this post
Link to post
Ça dégage l'horizon, c'est toujours ça de gagné :be:
Share this post
Link to post
Salut David,
Bravo, c'est une bien belle moisson d'images en poses courtes !
Continue ta quête, que ce soit sur Terre ou sur Arrakis ! ;)
Share this post
Link to post
Superbe série un grand bravo à toi!!
En attendant de découvrir tes futurs snipe dans ton nouveau terrain de jeu!!!!
Share this post
Link to post
Merci merci JMDSomme, Sauveur, William, Albéric, Vlaams59 et Utopix ;)
Davidastro a dit :
...la gravité à l'air vachement forte...
Excellent :cheesy:
JMDSomme a dit :
...tu as je trouve un "style"...
Merci, merci et remerci :):):)
Pour traiter mes images, je fais pas grand chose ;)
Je n'applique aucun filtre modifiant l'aspect global des images.
Je ne travaille que sur les lumières en faisant des calques de
zone et rien de plus.
J'aime bien que cela soit super agréable à regarder même
si pour cela, je dois perdre certain détail.
J'adore la douceur ;)
SpaceJu a dit :
...ça dégage l'horizon...
Excellent zaussi :p
Ryo a dit :
...je te souhaite de bonnes sessions pour 2018...
Et toi un new "Ryo Impact" ;)
wilexpel a dit :
...il y a de vraies pépites dans tes images...
Merci ma√ģtre Ioliam :)
Je t'avoue que j'en sais trop rien mais à force de voir d'autres images,
il est vrai que je me dis que le 254 à envoyer du très très bon sur
certain objet depuis mon centre ville ;)
xs_man a dit :
...Terre ou sur Arrakis...
Je réfléchi de plus en plus à retourner sur Arrakis car il va
bient√īt falloir se contenter d'une nuit par mois :p
Vlaams59 a dit :
...dans ton nouveau terrain de jeu...
Je suis en stress total sur mon new terrain :(
Tout est nickel pour y vivre mais pour l'astro, cela va être
la grosse surprise ;)
Je pense être opérationnel pas avant début Février.
C'est loin mais bon, comme il n'y a pas de ciel, c'est pas trop grave ;)
Utopix a dit :
...c'est exactement ce que j'aimerai faire...
Avec ton C11, cela doit le faire avec un réducteur ;)
donc go to snipe :)
Edited by Shaihulud
Share this post
Link to post
New lauch base :wub:
Deep Sky Planetary Technique 1.0 FASC (by Shaihulud)
Edited by Shaihulud
Share this post
Link to post
New process :wub:
Deep Sky Planetary Technique 2.0 FAPSSC (by Shaihulud)
Edited by Shaihulud
Share this post
Link to post
New lauch base :wub::wub::wub:
Deep Sky Planetary Technique 2.0 FAPSSC (by Shaihulud) :wub:
Traitement avec CS2
Je la kif aussi celle-là
https://scontent-cdg2-1.xx.fbcdn.net/v/t1.0-9/29512769_1609290422485657_1611587945522157906_n.png?_nc_cat=0&oh=0644707aa0583f1977ecf200e6ee775c&oe=5B3859E9 avec @Pulsar59 :wub:
Edited by Shaihulud
Share this post
Link to post
il y a 4 minutes, Davidastro a dit :
Les √©toiles sont un peu ovo√Įdes...
Je pense avoir trouvé une ptite réponse à mes étoiles un ptiot peu déformées :refl:
Avec Siril, je me suis aperçu qu'avec AS3, j’empilais facile jusqu'à FWHM 4,5 :cry:
Maintenant, c'est FWHM max 3 voir 3,4 donc j'ai moins de purée.
Share this post
Link to post
Donc tu fais une sélection plus draconienne !
Très belle nouvelles série, en particulier M101 qui est loin d'être facile.
Share this post
Link to post
Le retrait de gradient avec Siril c'est vraiment excellent :wub:
29595099_1591525560926005_32349528993772
Voili voilou le traitement de ma nouvelle victime :p
Pour le moment, je n'ai pas du tout travaillé les galaxies. Elles sont natures :be:
Version Deep Sky Planetary Technique 2.0 FAPSSC (by Shaihulud)
(FWHM conservé avec Siril 1,38 à 2,5 soit ~9800im/12000 x1,5s - QHY174MM gain 380)
29570630_1590659834345911_81553750966244
Nouvelle version : Deep Sky Planetary Technique 3.0 FAPSSSC (by Shaihulud)
Retrait de gradient sur l'image finale à la sortie de l'empilement Siril
(Au passage, j'ai testé et avec un FWHM conservé avec Siril 1,38 à 2,75 soit
~11000im/12000 x1,5s - QHY174MM gain 380. C'est le meilleur)
29573130_1591408270937734_54211005123187
Edited by Shaihulud
Share this post
Link to post
Au passage, je me suis fait un essai de traitement sur un image acquise et empilée pour msieur @Diabolo :be:
Une première pour moi le traitement version couleur :refl:
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
  • Recently Browsing   0 members
    No registered users viewing this page.
√ó
√ó
  • Create New...
Important Information
We have placed cookies on your device to help make this website better. You can adjust your cookie settings, otherwise we'll assume you're okay to continue.
