Salut à vous !
Après des problèmes de port COM sous windows 11 qui rendait aléatoire la détaction de ma monture, je suis passé à linux mint sur mon ordinateur (bon ça faisait longtemps que je voulais le faire pour sortir de windows...).
Je teste donc Ekos pour remplacer NINA.
Dès le début je bloque... je n'arrivre ps à connecter mes matériels.
Voici l'erreur retournée par EKOS quand j'essaye de connecter ma Terrans powerboxGo V2 :
2026-03-04T20:14:24: [ERROR] Failed to connect to port (/dev/serial/by-id/usb-1a86_USB_Serial-if00-port0). Error: Port failure Error: Permission denied. Try adding your user to the dialout group and restart (sudo adduser $USER dialout)
2026-03-04T20:14:24: [INFO] Trying connecting to /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0 @ 9600 ...
2026-03-04T20:14:23: [ERROR] Failed to connect to port (/dev/serial/by-id/usb-FTDI_FT230X_Basic_UART_D3092KVU-if00-port0). Error: Port failure Error: Permission denied. Try adding your user to the dialout group and restart (sudo adduser $USER dialout)
2026-03-04T20:14:23: [INFO] Trying connecting to /dev/serial/by-id/usb-FTDI_FT230X_Basic_UART_D3092KVU-if00-port0 @ 9600 ...
2026-03-04T20:14:22: [ERROR] Failed to connect to port (/dev/serial/by-id/usb-1a86_USB_Single_Serial_5971031424-if00). Error: Port failure Error: Permission denied. Try adding your user to the dialout group and restart (sudo adduser $USER dialout)
2026-03-04T20:14:22: [INFO] Trying connecting to /dev/serial/by-id/usb-1a86_USB_Single_Serial_5971031424-if00 @ 9600 ...
2026-03-04T20:14:21: [ERROR] Failed to connect to port (/dev/ttyUSB0). Error: Port failure Error: Permission denied. Try adding your user to the dialout group and restart (sudo adduser $USER dialout)
2026-03-04T20:14:21: [INFO] Trying connecting to /dev/ttyUSB0 @ 9600 ...
2026-03-04T20:14:20: [ERROR] Failed to connect to port (/dev/serial/by-id/usb-1a86_USB_Serial-if00-port0). Error: Port failure Error: Permission denied. Try adding your user to the dialout group and restart (sudo adduser $USER dialout)
2026-03-04T20:14:20: [INFO] Trying connecting to /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0 @ 9600 ...
2026-03-04T20:14:20: [ERROR] Failed to connect to port (/dev/serial/by-id/usb-FTDI_FT230X_Basic_UART_D3092KVU-if00-port0). Error: Port failure Error: Permission denied. Try adding your user to the dialout group and restart (sudo adduser $USER dialout)
2026-03-04T20:14:20: [INFO] Trying connecting to /dev/serial/by-id/usb-FTDI_FT230X_Basic_UART_D3092KVU-if00-port0 @ 9600 ...
2026-03-04T20:14:18: [ERROR] Failed to connect to port (/dev/serial/by-id/usb-1a86_USB_Single_Serial_5971031424-if00). Error: Port failure Error: Permission denied. Try adding your user to the dialout group and restart (sudo adduser $USER dialout)
2026-03-04T20:14:18: [INFO] Trying connecting to /dev/serial/by-id/usb-1a86_USB_Single_Serial_5971031424-if00 @ 9600 ...
2026-03-04T20:14:18: [WARNING] Communication with /dev/ttyUSB0 @ 9600 failed. Starting Auto Search...
2026-03-04T20:14:18: [ERROR] Failed to connect to port (/dev/ttyUSB0). Error: Port failure Error: Permission denied. Try adding your user to the dialout group and restart (sudo adduser $USER dialout)
J'ai essayé le sudo adduser $USER dialout avec mon nom d'utilisateur mais le terminal me répond
fatal: Le groupe « dialout » existe déjà.
Quelqu'un aurait une idée pour me débloquer ?
Bonsoir.
Tu as  écrit exactement comme indiquè ? La commande doit ajouter ton user (qui existe au group dialout).
Si tu tapes : echo <dollar>USER
Ca te rend bien ton user ?
J’ai mis <dollar> pour le caractere correspondant car je ne l’ai pas sur mon smartphone.
Tu peux mettre directement ton user devant le dialout
Merci !
J'ai tappé ça echo $USER
ça m'a répondu :
ben
qui est bien mon nom d'utilisateur...
OK je ne dois pas mettre le $
il me dit que ben a été ajouté, on va voir si ça marche maintenant...
Bon et bien ça ne change rien...
Pourtant ben a bien été ajouté à dialout...
Modifié par Tyru
Bon, j'ai redémarré l'ordi et ça marche. Je crois qu'il fallait faire ça pour que l'ajout au groupe dialout soit effectif.
Par contre ma caméra ZWO ASI 2600MC Pro ne se connecte pas (contrairement au flat panel qui est pourtant branché dessus...).
Le matériel séléctionné dans mon profil était juste nommé "ZWO CCD" peut être que c'est le problème... ?
Je ne trouve pas plus précis...
Est-ce qu'on peut mettre à jour indi ?
Modifié par Tyru
Ah non. Zwo ccd est bon. Dans le tableau de bord indi elle n’est pas connectée ? Si tu appuies sur le bouton connectèe ? Tu as  bien défini ton train optique ?
  • En ligne récemment   1 membre est en ligne
