Je suis nouveau possesseur d'un SeeStar S50Pro, et je me lance depuis quelques jours dans le traitement de mes images avec Siril (1.4.5)
J'ai téléchargé tous les scripts Veralux, quelques scripts SyQon.
'Prism' fonctionne dans problème, mais quand je veux lancer 'Starless', j'obtiens du message d'erreur :
13:52:05: Début du script C:\Users\Marc\AppData\Local\siril-scripts\SyQon/Starless.py
13:52:07: PyQt6 is installed
13:52:07: PySide6 is installed
13:52:07: astropy is installed
13:52:07: scipy is installed
13:52:07: Torch is already installed
13:52:10: torch-directml is installed
13:52:10: Connecting to Windows pipe: \\.\pipe\226d5bef-64b1-410c-a9a0-97f201b064c8
13:52:10: Connected to Siril
13:52:10: Could not check for updates to zenith.pt
13:52:10: Downloading Zenith Torch model (377 MB)...
13:52:10: Downloading from https://siril.syqon.it/zenith.pt.sha256...
13:52:11: Error: Failed to download SHA256 checksum: <urlopen error [SSL: TLSV1_ALERT_INTERNAL_ERROR] tlsv1 alert internal error (_ssl.c:1010)>
13:52:11: Download error (Attempt 1/3): HTTPSConnectionPool(host='siril.syqon.it', port=443): Max retries exceeded with url: /zenith.pt (Caused by SSLError(SSLError(1, '[SSL: TLSV1_ALERT_INTERNAL_ERROR] tlsv1 alert internal error (_ssl.c:1010)')))
13:52:17: Download error (Attempt 2/3): HTTPSConnectionPool(host='siril.syqon.it', port=443): Max retries exceeded with url: /zenith.pt (Caused by SSLError(SSLError(1, '[SSL: TLSV1_ALERT_INTERNAL_ERROR] tlsv1 alert internal error (_ssl.c:1010)')))
13:52:27: Download error (Attempt 3/3): HTTPSConnectionPool(host='siril.syqon.it', port=443): Max retries exceeded with url: /zenith.pt (Caused by SSLError(SSLError(1, '[SSL: TLSV1_ALERT_INTERNAL_ERROR] tlsv1 alert internal error (_ssl.c:1010)')))
13:52:42: Error downloading Zenith model. Cannot continue: Failed to download file from https://siril.syqon.it/zenith.pt after 3 attempts
13:52:43: Le processus Python (PID : 17660) s'est arrêté avec le statut 1
J'ai ensuite tenté le téléchargement direct à cette adresse : https://siril.syqon.it/zenith.pt
Que ce soit dans Chrome, Firefox, Edge ou Opéra, j'ai cette réponse : Ce site ne peut pas fournir de connexion sécurisée
siril.syqon.it a envoyé une réponse incorrecte.
Que faire svp ?
  • En ligne récemment   1 membre est en ligne
